Is it possible to use one soundcard for the TCV and then send the master sound back in to another soundcard to record? I have 2 soundcards and want to be able to use the 2nd for recording but it will only give me access to one in the soundcard menu.
geposted Mon 24 Apr 06 @ 11:51 pm
You can specify your other soundcard in the configuration window of the recording section.
geposted Mon 24 Apr 06 @ 11:56 pm
The only options are:
Master
Master + Mic
Line IN
How do I know which soundcard the line in is referring to?
Master
Master + Mic
Line IN
geposted Tue 25 Apr 06 @ 2:08 am
Sorry forgot to say, when you click line in it allows you to specify your soundcard then.
geposted Tue 25 Apr 06 @ 2:29 am
That's exactly what I needed. Thank you very much for your help.
geposted Tue 25 Apr 06 @ 2:45 am
