HELP IM HAVING TROUBLE WITH THE DATA BASE
WHAT HAPPENDS EVERY TIME I CLOSE THE VDJ IT DOESN'T CLOSE FAST IT GET'S INTO
DATABASE UPDATE AND THAT'S IT PROGRAME FREEZE IVE HAVETO USE ALT+CTRL DEL TO CLOSE
geposted Tue 25 Apr 06 @ 3:55 am
You also have something with your capslock :-)
(it's easier to read not all uppercase, please, e.g. someone may think you are shouting ...)
Do you have administartor privileges ?
Are you using "multi user" option in the settings ? try to switch it other way as it is now.
How many files you have, and what version are you using?
geposted Tue 25 Apr 06 @ 9:48 am
