I can reproduce it often:
- Load a track (A) then change its phase (CBG's)
- Load another track (B) in the other deck
- Set beatlock on B and play it
- Synch doesn't work well and seems to be accorded to the previous A phase.
=> I have to load A again (after CBG's were changed) and then beatlock on B works well.
==> Could anybody reproduce it too ?
geposted Thu 27 Apr 06 @ 7:25 am
This phenomenon also appears with the sampler.
- Load a track into A play it and change CBG's (left or right) to adapt the "Phase" parameter.
- Play a loop with the sampler accorded to the beat
=> It's synchronized with the original CBG's.
geposted Fri 28 Apr 06 @ 10:49 am
eagle eyes mate
geposted Thu 04 May 06 @ 12:26 am
Thanks ;)
It seems not to happen when we change BPM value.
I made the test with a track at 60Bpm. I changed this value to 120. Then I loaded another track at 120Bpm. The beatlock works correctly.
I have the problem only with the Phase parameter.
geposted Thu 04 May 06 @ 4:53 pm
