I am using Virtual DJ and Sunlite DMX software.
Sunlite has the ability to synchronize itself with any other program using MIDI Timecode. I was wondering if anyone had created a plug-in or if it would be possible to add the feature that Virtual DJ could send out MIDI Timecode on an active deck. The timecode itself could be the current position in the song being played.
The reason this is important is because if I create a timeline of lighting to sync with a song being played in Virtual DJ, then speed it up, slow it down, loop it, start it at a cue point, etc, the lights would remain in-sync.
Any help would be appreciated.
Thanks,
Randal
Thanks,
Randal
geposted Fri 28 Apr 06 @ 8:38 pm
Suggest it in "new feature" forum part;)
VDJ already support the Sunlite box, but if midi timecode is not implemented yet, please suggest it as a new feature;)
geposted Sat 29 Apr 06 @ 4:09 pm
