Forum: Old versions
Topic: Optical out?
I tried plugging my djconsole to my minidisc recorder to record a mix, but there seems to be no signal... I know the cable is fine, and so is the minidisc as it works with other optical equipement.
I did read the other posts on the subject, but I did not find a solution. Thanks for your help,
macourteau
geposted Wed 09 Jun 04 @ 12:47 am
I know that the optical output of my DJ Console is working (stereo only, I tried it on my amplifier).
I do not know if the input works... of course it should :|
There is no special configuration or anything I should know to "activate" it?
No, I don't think.
The main analog output must be a copy of the digital output.
Did your MD recorder have already works with digital input ?
On mine :
- MZ-R50
- MDS - M100
I must switch the record option to digital/optical
I don't have the djconsole, i'm using 2 soundcard with optical output (Terratec Sixpack 5.1+ and SBlive 5.1 Platinium + Live! drive IR) and on both i must activate optical on the config parts, they arn't active by default, maybe that the same with the DJconsole.
My MD recorder can only record from a digital source. It cannot output an optical signal. I wanted to record digitally what I'm mixing FROM the djconsole TO the MD player/recorder...
I know the MD's optical in works because I tried it successfully with other optical devices, but there doesn't seem to be a signal coming out of my djconsole's optical out port... :|
macourteau
Problem fixed -- I contacted Hercules and they said that sometimes the optical out doesn't work on some consoles when the USB port doesn't give the console enough power... They recommend a powered hub.
I have another computer here that had no devices attached to it, so I tested the console on that computer... And indeed, it worked. So I'll eventually have to get a powered USB hub...
macourteau
Ok! We really thank you for this feedback.
We now have to hope that other people having the same problem will be able to find this post
That's why I posted the solution to my problem ;)
I have tryed to connect the console (digital out) to Spdif-In of my soundcard and it doesn't work.
Need some settings?
