Hello,
The broadcast server are running but nobody can log in ?
I use Virtual DJ 3.4
geposted Mon 01 May 06 @ 9:51 pm
geposted Mon 01 May 06 @ 10:45 pm
If I the extrentie work 8000.pls in Winamp open as url then it, works!
But if I :8000/VirtualDJ.mp3 click it does not work in intenret explore
geposted Tue 02 May 06 @ 7:42 pm
Now there one user stand listen, but at these user Winamp do not open ???
geposted Tue 02 May 06 @ 7:59 pm
NoBody ?
geposted Thu 04 May 06 @ 12:25 pm
Some my frineds listen me sometime with winamp without any problem
geposted Thu 04 May 06 @ 1:57 pm
Yes okay, but I have the problem that I users see those listening also friends, but at none 1 Winamp open that nevertheless strange are
geposted Thu 04 May 06 @ 9:50 pm
do you have a static ip adress (one that stays the same each time) , if not you will need to configure a dynamic dns link you can find many free providers of this service on google.
if you have a router you will need to configure port forwarding or it is aslo unlikey to work
check your manual on how to do this
hope this info helps!
Simon.b
Simon.b
geposted Sat 06 May 06 @ 12:12 am
