Does anybody knows when and if the xp-10's will be available for purchase over the web page ?
thanks a lot
thanks a lot
geposted Tue 02 May 06 @ 8:27 pm
The XP10 are voluntarely Out of Stock.
The EKS XP10 became cheaper to buy and they work just as good with VDJ.
geposted Tue 02 May 06 @ 9:16 pm
I went to EKS web page and the xp-10's are sold for 399.00 euros comparing to VDJ at 299.00 euros.
so in other words ??????????.....VDJ won't have them anymore ????????????
thanks
thanks
geposted Tue 02 May 06 @ 10:09 pm
Hi, can somebody please tell me if XP10 works as a single player with both turntables?or have to be two XP10 controllers.
geposted Fri 05 May 06 @ 7:07 pm
@MUSIKGUATE http://www.thomann.de/thoiw2_eks_xp10_prodinfo.html 295 EUR ;)
@generalu no, you can't use one controller to controll booth decks.
geposted Fri 05 May 06 @ 7:17 pm
I read somewhere that, in fact, you can control both decks with one xp-10, with the shift button, if you check on the general forum somewhere is an explanation how you do it.
geposted Mon 08 May 06 @ 10:43 pm
I have only one XP10 controller and it is working with both players. There is button for switching between players A or B. I can control only one player at the time.
geposted Tue 09 May 06 @ 2:57 am
I couldn't ever set it to work. Tryed a lot of times. Anyway.. with 2 of them is much easier ;)
geposted Tue 09 May 06 @ 9:54 am
so Ludek you can mix with one XP1 controller?
geposted Wed 10 May 06 @ 4:58 pm
Yes, without problem. I have internal PCI soundcard with two stereo outputs and external mixer. One deck (red) is playing from speakers and other (green) i can hear from headphones and control with XP10. After mixing i must swith XP10 to the first deck and prepare next song (cue, tempo..), etc, etc...stilll around.. :-)
geposted Wed 10 May 06 @ 6:39 pm
