i dont understand how this new beatlock works now.....b4 i would keep them both on and everything worked fine......now if they are both on you cant move the pitch sliders???
geposted Fri 11 Jun 04 @ 1:58 am
It is because you do not need to lock them both.
Do not lock the desk you want to change. All other locked players ( desk AND samples) will follow this master.
Good Mix ;)
Good Mix ;)
geposted Fri 11 Jun 04 @ 6:47 am
i had the same problem until i realised some of the skins only have 1 beatlock button. beatlock only works properly on the skins that have beatlock on each desk such as the default skin. it is just a matter of skin updates and then your problem will be fixed.
geposted Fri 11 Jun 04 @ 7:00 am
Yes the beatlock is now per desk. You'll understand easily when you'll try the new powerfull network sync :)
geposted Fri 11 Jun 04 @ 8:11 am
