Where can i find a (800*600) Default Skin that works with version 3.4 ?
I found one under the Skin Download section but the font on it is so small ... you can hardly read it ... i am guessing its because the (800x600)default skin thats posted up is for vers 2.xx
anyone know where i can find a working version for vers 3.4 ?
If not ... can someone tell me how i can modify the skins font size so i can read it
geposted Fri 05 May 06 @ 10:53 am
There should be a few 800x600 skins in the skin download section, inc the default...
And there is a tool that converts to 800x600 that works ok:
https://virtualdj.com/addons/skin.html?id=45
geposted Fri 05 May 06 @ 12:08 pm
