.. yeah that can be usefull sometimes I think...
geposted Mon 08 May 06 @ 9:56 am
This is possible with the DJ console mapper from DJ Cel
geposted Mon 08 May 06 @ 11:54 am
Please explain. I too am in need of a shortcut or combination to temporarily disable the wheels on the fly. Cheers Brian.
geposted Thu 11 May 06 @ 11:49 am
This will be implemented in new mapper come from TexZK user, the idea is a little windows with some buttons with the possibility to enable and disable the jog, see my work on skin where you can see a preview image of the mapper. http://www.virtualdj.com/blog/cioce/?category=2
Don't worry, the last beta version have the jog ON-OFF buttons.
In any case you can use the DJCEL mapper v2.0 to disable, I will make a print screen of the mapper setup this evening when I will be at home with my computer and console.
geposted Thu 11 May 06 @ 11:57 am
