Hi there
i recently bought the behringer bcd2000, its a great controller with all the bits and buttons you need. Unfortunately the software is very unstable and the audio stuttery. The control also doesn't seem to comply with standard MIDI.
Is there a possibility of native support for the bcd2000, i've been trying the virtual dj 3 demo and really like the software.
cheers
Tom
cheers
Tom
geposted Mon 08 May 06 @ 12:29 pm
For the moment there is no native support for BCD2000, but you can control VDJ with alot of the BCD2000 functions through midi.
VDJ has built in midi, and you can create shortcuts that are controlled by midi.
But i'm afraid the trial version doesn't have midi enabled.
geposted Mon 08 May 06 @ 1:14 pm
We want to know when they are going to support the controller? Also don't buy it without support who knows when this will happen.Promises are made to be broken.
geposted Mon 08 May 06 @ 1:32 pm
Actually it does..
Actually it does..
geposted Mon 08 May 06 @ 6:55 pm
yep, as soon as its supported i'm buying virtual DJ
geposted Mon 08 May 06 @ 9:33 pm
