Hi Everyone.......I just got my TCV today, everything works great, minus the annoying high pitch whine I hear from my needles but anyway
Under the MK2 Time Code Settings there is a "Lead Time" in ms......its defaulted to 500, what is this and where should it be set, my issue is Im getting 100% TC signal, but there is a "lag" between my Vinyl movement and the actual sound Im hearing from the MP3.........
Shouldnt it be close to exact as possible since some scratching requires very fine record movement
Thaks...:)
Thaks...:)
geposted Tue 09 May 06 @ 4:08 am
You need to adjust the latency from the Mk2 driver to as low as it will go (i.e. 441). The lead in time is how much timecode is played at the very beginning before the timecode is considered active. This is so you can scratch the first beat and leaving it at the default is fine.
geposted Tue 09 May 06 @ 6:39 pm
