I'm about to buy myself a new computer and I'm asking myself:
Will the skins that's in 4:3 still work on my widescreen laptop, or will I be forced to use
skins which are 16:9?
Take a look at the spec. on my new computer. Do you think VDJ will run good? what's your oppinion
Intel ® Core™ Duo Processor T2400 1.83 GHz, 2 MB L2 cache, 667 MHz FSB....- maybe 2 GHz is better?
Windows® XP Professional
1024MB 533MHz DDR2 SDRAM (2x512)
100GB (5,400 rpm) Hard Drive
15.4" UltraSharp™ W Screen SXGA+ TFT Display resolution: 1680x1050 with TrueLife
256MB ATI® MOBILITY™ RADEON® X1400 graphics card, PCI-Express x16 --
Will this work with Virtual DJ? If not, what's missing..
Last but not least I want to tell everybody that I love VIRTUAL DJ
I'm also thinking bout bying that good looking HERKULES MK2...
Is this the best DJ station to work on Virtual DJ?
geposted Tue 09 May 06 @ 6:56 pm
Your pc will work good, and 4:3 skins will work too, on widescreen monitors
I really think you should also consider buying the software as part of your upgrade;)
The mk2 controller is good, but there are many others as well, and timecode too...
Its all a matter of personal choice;)
geposted Tue 09 May 06 @ 8:10 pm
