Hey VDJers:
I have a small problem or "wish".
I like to browse through my tracks and drag them into the play list as a track that I may play a little latter. Then, throughout the set, I'll glance at the play list for anything I might play next. Unfortunately, I can not see the BPM without having to look up the track in the Local Database. Is there any way to get the BPM to show up in the play list?
Thanks Much,
Mat
Thanks Much,
Mat
geposted Wed 10 May 06 @ 4:10 pm
Hi,
If you are referring to the play list on the right, then yes you can expand the columns to view :
author - title - bpm - length - comment
This works the same as for the browser window.
-hope that helps, Dj Los.
geposted Wed 10 May 06 @ 4:15 pm
Mat,
You need to grab the tag headers and drag them to the left, they are just hidden off the screen and overlapping each other.
geposted Wed 10 May 06 @ 4:48 pm
Hey guys:
Thank you, that was it.
Mat
Mat
geposted Wed 10 May 06 @ 6:13 pm
