Topic: sampler
jukesyPRO InfinityMember since 2003
Can we sample loops that are longer than one bar?
I see that the software comes with many .vdj loop examples and some of these are 4 bars long. How were they sampled?
Also
If you could make VDJ read .rex, .map and .sf2 files then let VDJ play them back at any tempo by time stretching the loop that would be great.
Steve
geposted Fri 11 Jun 04 @ 3:31 pm
According to the manual (I read it! believe it or not) it's possible to make sample loops on the fly. I tried to sample an 8 beat loop and it worked. I think it should also work with a 32 beat loop or more.
Does this answer your first question? I hope it does.
GnoedeL
geposted Fri 11 Jun 04 @ 4:28 pm
The sample can be a 128 beats lenght.
geposted Fri 11 Jun 04 @ 4:41 pm
jukesy
Read other format ok, but the beatlock for the sampler work better with .vdj because that not juste a sample, this files containe lot of information about the BPM, the Eq information, of the sample.
geposted Fri 11 Jun 04 @ 4:45 pm
NAWTBOYPRO InfinityMember since 2003
where did you read this in the manual???
I didn't think there was an updated manual available yet??
geposted Fri 11 Jun 04 @ 5:17 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
Pdf file included is updated...
geposted Fri 11 Jun 04 @ 7:42 pm
maus75PRO InfinityMember since 2003
"jukesy
Read other format ok, but the beatlock for the sampler work better with .vdj because that not juste a sample, this files containe lot of information about the BPM, the Eq information, of the sample."
Thats odd, if i rename the vdj samples 2 mp3 then they are simply mp3's. It seems to work backwards to !!
So if you have samples in mp3, just rename them to .vdj.
Hope that explains that the vdj file is nothing more or less then mp3 ?!
geposted Thu 29 Jul 04 @ 1:00 am
