hmm... please help
Error Code: -5009 : 0x8002802b
Error Information:
>Ctor\ObjectWrapper.cpp (163)
>Ctor\ObjectWrapper.cpp (391)
>Kernel\Component.cpp (1163)
>Kernel\CABFile.cpp (384)
>SetupDLL\SetupDLL.cpp (1526)
PAPP:Hercules DJ Console Series
PVENDOR:Hercules (http://www.Hercules.com)
PGUID:E4BC9EE4-67F8-4335-BF46-BDACE314BCF6
$11.0.0.28844
@Windows XP Service Pack 2 (2600) IE 6.0.2900.2180
i dont know what to do..... this is the messega i got when im trying to install from the cd i really need help!!!!!
Error Information:
$11.0.0.28844
geposted Thu 11 May 06 @ 12:03 pm
You should contact Hercules support
geposted Thu 11 May 06 @ 12:04 pm
i cant get my password for their site dont know why :(
geposted Thu 11 May 06 @ 12:07 pm
try downloading the seprate installer from the website or the update it should work:)
geposted Thu 11 May 06 @ 3:28 pm
and are u using XP?
already treid to download from the website but no luck :(
yes im using xp and i really need some help.
did you have the same problem???
geposted Thu 11 May 06 @ 4:27 pm
are u logged in as admin?
geposted Thu 11 May 06 @ 4:30 pm
yes
geposted Thu 11 May 06 @ 4:36 pm
please help
geposted Thu 11 May 06 @ 4:43 pm
Try a clean install
- Uninstall the Hercules driver
- Reboot
- Download and install the latest version of the driver www.hercules.com (contact hercules support if you have problem to log on)
- Don't forget to connect the controller only when the install driver ask for it !
Hope this help
- Reboot
Hope this help
geposted Thu 11 May 06 @ 5:48 pm
if that doesnt work
you can try using regedit
go to run on your startmenu
then type regedit
when on regedit do a search for vdj or hercles and delete any keys u find
if you are at all unsure of how do to it
download the free trial of system mechanic from www.iolo.com
and run a registry clean and it should remove it for you
then type regedit
geposted Thu 11 May 06 @ 7:36 pm
Warning !
Always make a registry backup before any change there, a bad change can make a crash of program or your computer.
geposted Thu 11 May 06 @ 7:47 pm
if u use the system mechanic way it backs up for u or u can save the registy as a single file using regedit
geposted Thu 11 May 06 @ 10:18 pm
gaaaaah..... nothing works :(
i think the only way is to format my hard drive.....
Thanks for the help guys
geposted Sun 14 May 06 @ 1:44 pm
