Hey guys, I have this Dell latitude d610 laptop
pentium 1.73 ghz
1.25 mb ram
40g HD
mobility radeon x300
What do you think, will it be good to run VDJ ?
I already have 2Numark TTX TT's , a 3 channel behringer mixer, and Im waiting for my TCV any day now, but Im wondering about this laptop..
I also wanted to know, if you can install VDJ in more than one laptop or desk top?
Thanks in advance..
pentium 1.73 ghz
1.25 mb ram
40g HD
Thanks in advance..
geposted Fri 12 May 06 @ 8:22 am
I think it's good and you can work fine with Virtual DJ, probably you have 1256 Gb ram ;-))
In any case try to read here https://virtualdj.com/forums/44427/Hardware_Technical_Support/Computer_Specs.html
geposted Fri 12 May 06 @ 9:10 am
yes it should be fine:)
geposted Fri 12 May 06 @ 10:52 am
probably 1024 + 256 mb RAM which is in total 1280 mb physical RAM. :)
geposted Sat 13 May 06 @ 1:53 pm
The best laptop I found today is which use ATI X1400 video card and a Intel-Dual Core with 1GB (or more) or DDR2 RAM. From Dell maybe a Inspirion 9400 it's better than that DELL Latitude. Anyway, it's a good laptop but X300 video card isn't the best to do video...
geposted Fri 19 May 06 @ 8:27 am
