i click it and it opens to the loading screen.after that, it go's down to the taskbar and it doesnt display the image.it says its running but i cant play it.Whats wrong?
geposted Sat 13 May 06 @ 9:42 pm
Is this the Demo version?
geposted Sat 13 May 06 @ 10:07 pm
try reinstalling
geposted Sun 14 May 06 @ 1:27 am
Put your screen resolution to 1024 x 768
geposted Sun 14 May 06 @ 2:04 am
i dont know how to start my own thread so ill just ask here, i got atomix and how come it takes like 50mb just to save a 4 min song?
geposted Sun 14 May 06 @ 2:40 am
because its an very old encoder saving at high quality , if you want a better recording system , purchase virtual dj pro!
prehaps you should buy atomix ... aslo or put ur licence code on ur profile.
geposted Sun 14 May 06 @ 11:43 am
AtomixMP3 read the .mp3 format but don't use an encoder when you record with it (the recording is in .wav format) You have to use an external encoder to encode the result in .wav to the .mp3 format
If you want to encode your song directly, use Virtual DJ
geposted Sun 14 May 06 @ 3:56 pm
Kayle is correct change your resolution u probably have the wrong skin on
geposted Sun 14 May 06 @ 6:36 pm
