Forum: VirtualDJ Skins
Topic: "Mix Station SV04"
Serge, PLEASE make a 2.0 compatible version of your skin!
It is the best.
Regards,
Ronny582
geposted Fri 11 Jun 04 @ 9:02 pm
Hello Ronny,
You know, Serge discovered the 2.0 just yesterday like you, so let him sum time to upgrade his skin, he will surely do it.
By the way, the beatlock feature in the MixStation is already working with the 2.0, so you can mix with.
FRUiT94
I tried the mixstation; everything seems to work properly.
I will gladly give him all the time he needs. I just really think this skin is so functional. It makes the job great to be creative with this skin. Just showing my enthusiasm for his work, not nagging!
Thanks in advance Serge!
Ronny
Hi Serge,
I downloaded, installed and tested quickly your last release.
Great job !
Laurent.
