So I just bought a powerhouse laptop (WOOHOO!)(dual core 2ghz, 2G ram, 256 ATI x4000, SBLive!) but i have far more music than it will hold..
obviously i'll be getting an external hard drive....
My question is that i am going to be using primarily my hercules mk2 (USB device)
If i purchase a USB external hard drive, will this hinder performance of either very much? USB hard drives are cheaper than firewires- which would be my alternative if it's a bad idea to run both devices through the USB bus.
geposted Mon 15 May 06 @ 3:39 am
If you can buy firewire do it as in general users have some problems with the USB (sound card +hard disc) and we advise them to buy a usb hub with power supply
geposted Mon 15 May 06 @ 4:19 am
will do!
thanks for the speedy response
geposted Mon 15 May 06 @ 4:26 am
I have firewire hd and works great. buy it if you can.
geposted Mon 15 May 06 @ 10:41 am
Hi there!
Just remember that USB 2.0 is the fastest connection you can use... if you can combine a 7.500rpm or 10.000RPM hdd...great!
Good luck!
Good luck!
geposted Tue 16 May 06 @ 8:57 pm
Theory shows that USB2 is faster than firewire.
But when doing some important tests Firewire is faster.
geposted Tue 16 May 06 @ 9:43 pm
max speed of USB is 480 Mbps, and FireWire is 400 Mbps.
"USB 2.0 - 480 Mbps
FireWire 1394 - 400 Mbps"
www.geekforums.com
"USB 2.0 - 480 Mbps
www.geekforums.com
geposted Tue 16 May 06 @ 11:47 pm
Yes but i think it's the buffer size that is smaller for FireWire and it make the transfer rate more important for FireWire.
You will never get 480Mbps with USB2 but something like 350-400. And i think you get 380 with FireWire.
geposted Wed 17 May 06 @ 12:47 am
thanks for the great info guys, i think im convinced to go firewire... just cause im already running so much on usb- small keyboard light, mouse, hercules mk2, and from what you say, the two are practically similar
thanks again!
thanks again!
geposted Wed 17 May 06 @ 2:31 am
Jeremie is right. Firewire is faster. I wrote this loooong ago. check the forum. you should be able to find my old post with explanation.
geposted Wed 17 May 06 @ 2:36 am
Thanks Xeon.
I found your old post, it is here:
https://virtualdj.com/forums/12935/Software_Technical_Support/VDJ_and_mp3s_on_different_drive_partitions_.html?page=2
geposted Wed 17 May 06 @ 2:41 pm
