Hi Dj friends,
i am a vinyl junky slowly moving into mp3 and wave mixing. Which soundcards is the easiest - best to use with a laptop pc? needn't be top of range at this stage i am setting up cheaply to test the waters etc. thankx
geposted Tue 16 May 06 @ 5:33 pm
Hi there...
Well, many professionals may recomend a lot of expensive sound cards...but the truth is you wil not gain much using them with home stuff!
So, there are many solutions in the market... the hercules "www.hercules.com" stuff are ok! If you are using virtual DJ 3.x with any 5.1 cheap soundcard you can pre-listen using both "rear" and "front" plugs.
You just have to remember to things by the time to decide:
- Computer cheap stuff uses "mini jack" stuff...
. Most sound equipment uses RCA...
But you can allways use some adapters..
Good Luck!
Good Luck!
geposted Tue 16 May 06 @ 8:52 pm
