hi all
i have a problem with my djc mk2 : when i plug a speaker in the 3-4 output and if the headphones selection is 'mix', it's work correctly but if i change the headphones selection, i hear "all sounds" on the speakers (independently of the crossfader position) !!!
help me please
romain
help me please
romain
geposted Wed 17 May 06 @ 7:27 pm
If you look in the manual it says that inputs 3/4 will be the same as the headphone output. I've found a couple ways to get around this, if you have a vregular mixer with multiple outputs use "use external mixer" and run it that way. Otherwise, you could just use splitters on inputs 1/2;^]
geposted Thu 18 May 06 @ 4:56 am
ok thanx !!! i've just read it in the manual
geposted Thu 18 May 06 @ 12:29 pm
