hi im going to by the softwear but im looking around but im worndering can i mix wit turn tables like this
http://www.rane.com/SeratoScratchLive_High.mov
if so what do i need to get the so mix like that if i was to buy virtual dj
what would i buy i have one sound card wit mic input and headphone output
geposted Thu 18 May 06 @ 12:03 am
You will need VDJ Pro.
And 2 TimeCodedVinyls (TCVs) you can get them here: https://virtualdj.com/shop/
And you will need an ASIO soundcard with 2 or more stereo outputs and inputs. Like the maya44usb, or the ESI U46DJ which is highly recommended for VirtualDJ.
geposted Thu 18 May 06 @ 1:50 pm
would it be easer if i buy the m2k mixer and get the virtual dj pro and then buy a x10 from u guys
geposted Thu 18 May 06 @ 10:28 pm
Thats the route I plan on taking when I get the $$$ for the XP-10's.
geposted Fri 19 May 06 @ 10:35 am
