Will the Timecoded vinyl work with the Hercules MK2 contorller/sound card? I was at a local retail store and one of the guys that worked there had your software with the timecoded vinyl and it worked great. He also showed me the MK2 console but he didn't know if they would work together. So I thought I would ask.
Thanks!
Thanks!
geposted Thu 18 May 06 @ 5:31 pm
From what I've read so far the mk2 provides very low latency use of TCV, so I think the answer is yes. I sure hope so, I've already ordered my TCV & am upgrading to pro with my june check;^]
geposted Thu 18 May 06 @ 8:11 pm
I can confirm they work together, you can even use the functions of the Mk2 with the TCV, e.g. loop, cues and fx.
geposted Thu 18 May 06 @ 10:24 pm
i use them and its Great:)
geposted Fri 19 May 06 @ 10:29 am
