Hi!
I'm testing the VDJ 1.08, and wonder if it is possible to get the beatlock functionallity to be set for an entire playlist.
What I would like to do is to select a couple of songs and then arrange them in a certain order (depending on BMP and genre). The I would like VDJ to make mixes without that I have to click the beatlock button.
Possible? Plugins? Other products?
/Nenne
/Nenne
geposted Sat 12 Jun 04 @ 12:09 pm
Yes everything's possible with VDJ.
Make your playlist on the right column and click on the first star. Everything will be played and mixed. Organise the way to mix some tracks with a right click on each track you want to organise and select automix than enter your parameters.
Good mix with VDJ
Clax
Good mix with VDJ
Clax
geposted Sat 12 Jun 04 @ 7:02 pm
If I right click on a song, in VDJ Playlist I only get one choice "Listen".
Automix I've found, but automix doesn't perform beatmixes, it just moves the crossfader. And that feature is possible with Winamp and plugins.
Or is there another setting that I've missed?
/Nenne
/Nenne
geposted Sun 13 Jun 04 @ 9:26 am
You have to activate the beatlock on EACH deck, on a 2.0 compatable skin. (which skin are U using?). You also have to go to the options in the "fame tab" to tell to VDJ it must beatlock all new song loaded in a player (the first option in that pane, called "automatic BPM").
FRUiT94
FRUiT94
geposted Sun 13 Jun 04 @ 11:43 am
Ok, now I noticed, the application removes the beatlock, but when it's time for the next mix, it enables it again. Hmm, no error in the application nor me, just a confusing GUI.
Thanks all for the help, now I will evalutate.
/Nenne
/Nenne
geposted Sun 13 Jun 04 @ 5:52 pm
