Forum: Old versions
Topic: Problems with playing 2 TCVs at the same time.
Hi.
I've got a Maya 44 USB, 2 TTs, 1 Mixer and 2 TCVs.
I've plugged everything in like it was shown in the picture in this blog.
https://virtualdj.com/blog/l_rids/blog2598.html
But the problem is that virtual dj can't detect one of the TCVs.
The other one is playing without problem...
I think it could be a problem with the maya or the drivers... I don't know.
Hope you can help...
*Sry 4 my english :)*
MfG,
DeeTaG
geposted Fri 19 May 06 @ 9:06 pm
That picture is from Dams... and l_rids can remember... it's a Corporate User! lol ...
https://virtualdj.com/blog/Dams/blog738.html
DJ DeeTaG, I think the problem is on the Maya it self. If you can switch the cable connectors from TT1 from TT2 and got the same problem in the TT that was playing good in the other channels, the problem is in the Maya (maybe a missed configuration). If the problem stays in the TT that don't play in either channel, it's a cable problem in the TT connects for sure.
I think I read something about this problem, I going to take a look if these don't help you find the problem.
Good Luck!
What does the other picture look like for your other turntable? If it looks like this: https://virtualdj.com/blog/Mannas/ the one on the right, the Maya's messed up. I had one with the similar problem and 1 set of inputs was messed up it just put out constant static, even with nothing plugged into it.
HOW CAN I SYNC MY VINYLS PREFECTLY, THERE SEEMS TO BE A SLIGHT DELAY BETWEEN MY LAPTOP AND MY VINYLS, I'VE TRIED CHANGING THE LATENCY; IT HELPS BUT HOW CAN I SYNC THEM PERFECTLY SO THAT WHEN I TOUCH THE VINYL WITH MY HANDS, I GET AND INSTANT REACTION FROM THE MUSIC.
ANOTHER QUESTIONN: WHAT IS THE MUST HAVE SOUNDCARD TO RUN....I HAVE A COMPAQ W/ ATHLON XP-M PROCESSOR 2.24 GHZ, 1028 RAM AND AND EXTERNAL HARD-DRIVE. I HAVE A BIG CLUB THAT I'M DOING THIS WEEKEND AND I WANT THE CONFIGURATIONS TO BE PERFECT....PLEASE ADVISE COMMENTS.
if there is a delay and the scratch sound is rubbish its probably too high latency. If your realy stuck try using ASIO for all on your maya instead of your normal ASIO
I had the problem with VDJ only recognizing one TCV. It turned out the routing of inputs from my ESI U46DJ had gone haywire ever since I started mugging a bit with Virtual Audio Cable. I ended up having to reinstall my laptop from scratch. Will never touch VAC, Total Recorder or anything that messes with the internal audio routing again on my VDJ machine, that´s for sure!
