Hey everybody. I had install Winamp's Plugings of Nullsoft for make a "web radio" on my own computer. Now, I search to diffuse in the web the sound of VDJ and not of my mic or of my Winamp's Playlist. Anybody know what I can do it ?
geposted Sat 20 May 06 @ 9:30 pm
sorry im confused why are you trying installing a nulsoft server when theres one already built in to vdj
geposted Sun 21 May 06 @ 1:10 am
oh. I d'ont know this... so what I can do to diffuse my mix in internet ??
geposted Sun 21 May 06 @ 12:48 pm
in Vdj , go to the record tab and just pick broadcast and then Config and follow the instructions on screen.
geposted Sun 21 May 06 @ 1:26 pm
ok ! I found. Thanks you. But, it's normal that a little time separe the sound of my own computer and the computer who listen my server ? (cofiguration : Nullsoft Server // VDJ => Broadcast : Broadcast on a radio server => 127.0.0.1 port 8005 )
geposted Sun 21 May 06 @ 1:33 pm
there will always be a delay bettween the Server and the listener as it takes about 30 secconds to be processed. This goes for any broadcasting with or with out virtual dj.
geposted Sun 21 May 06 @ 1:36 pm
you can reduce this gap by limiting other programs acess to the internet , as this gives vdj more bandwith.
are you using the trial version?
geposted Sun 21 May 06 @ 1:39 pm
ok !! thanks you very much for your help !! good bye and i hope see you soon
geposted Sun 21 May 06 @ 1:41 pm
glad i could help.
geposted Sun 21 May 06 @ 1:46 pm
helloi am using vdj home edition
bu twhen i click on broathcasting he shows a screen with options and i can't conect
geposted Fri 16 Jun 06 @ 7:10 pm
ok please add ur serial to ur profile to get the latest update as this is now fixed ,
aslo check that you have a direct line and not a router!:)
geposted Sun 18 Jun 06 @ 2:56 am
