I noticed one of the Numark skins had loop in/ out and it worked great. Problem is the skin is too big & then when my monitor adjusts to keep it all on screen it becomes too small to see from my elivated angle. My question is there a better skin with this feature? I'm using the Tascam skin now, thanks;^]
geposted Sun 21 May 06 @ 12:09 am
On the default skin, if you right-click on the two loop knobs for shift and lenght, it will act as loop-in/loop-out.
geposted Mon 22 May 06 @ 4:48 pm
Are there any keyboard short cuts to loop in/ out? I love the tascam skin & the default skin only has loop to 16 whereas the tascam skin adds 32 and 64. Thanks;^]
geposted Thu 25 May 06 @ 8:53 pm
Not sure if there's a keyboard shortcut already there or not, but you can set up any shortcut you want in the config...
geposted Sat 27 May 06 @ 6:41 pm
That works, done and done, Thanks!!!;^]
geposted Sat 27 May 06 @ 9:21 pm
