I have everything inputed and outputed right, now how do i record w/ my TCVs on virtual dj? I tried putting the outputs of my mixer to the MIC input on my laptop but no luck...what should i do now?
geposted Sun 21 May 06 @ 7:35 pm
Use the line in of your computer rather than the mic input. Mic is meant for phono devices and is usually mono. Once you have the connections sorted, open the recording options of Virtual DJ and select to record from line in.
geposted Sun 21 May 06 @ 7:53 pm
well the only line input that I have is a single mic input, which makes the sound quality very poor. is their any other solution to my problem?
geposted Sat 27 May 06 @ 11:23 pm
why asked twice??? anyway... read my answer at your another post.
geposted Sun 28 May 06 @ 1:00 am
are you sure there is only a mic input?
on my laptop i have also one mic in but in the record settings of the onboard soundcard i can switch it from mic to line in. but there is only one hole.
geposted Sun 28 May 06 @ 12:49 pm
hmm, interesting...I will try that! I don't know if that will work for me, what should I do if it doesn't work??
geposted Mon 29 May 06 @ 5:02 pm
if that doesn't work i suggest you buy a cheap soundcard with a line in.
geposted Mon 29 May 06 @ 11:21 pm
