i just downloaded the update for the mk2 and now my vdj 3.1 wont recognize my console i already tried removing the softwares and reinstaling them it wont work....PLEASE HELP ME OUT
geposted Sun 21 May 06 @ 11:30 pm
How can you update if your are not registred has a MK2 user on the VDJ web site ?
geposted Sun 21 May 06 @ 11:34 pm
v.3.1 its the standard version from virtual dj on cd with the mk2 when he installed the new mk2 drivers will not work with 3.1 now because work only with 3.2 and 3.3 yet.and the last updates for the djc version are 3.3 and 3.4
geposted Mon 22 May 06 @ 12:07 pm
, id advise you to download the updates as mentioned and the console firm ware this should be bundled with the drivers
aslo add your serial to your page :)
you can do it by pressing modify my profile
geposted Mon 22 May 06 @ 4:52 pm
