I am probably doing something wrong, but I cannot find a user manual for the program so this is what I have done sofar and the result :
- I start ripvinyl.exe
- in Config I choose an audiosource
- then I setup the necessary faders
- I sign some boxes
- give a bitrate from 160
- with the knob [...] I write "lame_enc.dll" as the mp3 encoder
- I try to REC
- stop recording with SAVE
- fill in a filename Enter and then I get an Errormessage : Impossible to save "c: etc...
Where am I going wrong ?
Greeeeeeeeeeetzzz Frans
- I sign some boxes
- I try to REC
geposted Mon 22 May 06 @ 6:27 pm
          to less harddriver memory
    geposted Mon 22 May 06 @ 6:45 pm
          Free up some space , run a disc clean ect.
    geposted Mon 22 May 06 @ 10:38 pm
          The odd thing is that I can record audio in the full program of VDJ 3.4 also with other audio software for example soundforge 8.0 works fine.
I have enough space on my HD and also in RAM but how can I assign more memory to the ripvinyl.exe ?,
geposted Wed 24 May 06 @ 7:42 am
          Alt Control Delete - task manager
go to processes and then go to ripvynal.exe and select high priority.
geposted Wed 24 May 06 @ 10:22 am
          Hello
I'm having the same problem, a followed the steps above but i still get the error message.
Can somebody help me?
Greets
Kristof
Greets
Kristof
geposted Tue 11 Jul 06 @ 1:48 am
          Are you using the trial version or the complete version ?
    geposted Tue 15 Aug 06 @ 9:57 am
