Hello,
I'vee been using VDJ for about a year now and love it.
I usually connect to my home stereo, or to a club system via the Hercules RCA channels 1 & 2 (front). I can get good sound, but when I connect on RCA channels 3 & 4 (centre) the sound is far superior, but then my Hercules cross fader does not work - I can only get external sound on one deck.
Any solutions to this, or better yet, how can I effectively use RCA channels 3 & 4 (centre) on my system?
Thanks in advance...
Sirslick
Sirslick
geposted Tue 23 May 06 @ 11:05 pm
Do you have MK2 console ?
I had mk1 and both outputs were OK. But instead of setting Hercules DJ console in the sound settings,
choose "advanced config" that should work for using external mixer.
Or search the forums, "DJ in norway" has some important things to say in his posts regarding external mixer support, as there was firmware and VDJ update for Hercules Console.
I am not using console for over a year... :-( so maybe the situation changed ....
geposted Wed 24 May 06 @ 1:09 pm
acw_dj please correct this link :) it is going to edit your blog, not just open it to see :)
geposted Sun 28 May 06 @ 8:39 pm
