I mix using 3 turntables and was wondering if i could use your software with 3 Behringer UCA202 and time code vinyl plugged into diffrent usb ports on the same computer, using multi-instances of VDJ. I ask as the Behringer UCA202 will be a very cheap and simple option if it will work. Thanks for any help :-)
geposted Wed 24 May 06 @ 12:03 am
