hi there - bit awkward to explain this so i'll do it step by step ...
1 turn computer on
2 start vdj shortcut to use external mixer (djm 300)
3 start vdj main program
4 start mixing then go back to shortcut and find external mixer turned off ! reset it and no further problem..
5 mix 1st and 2nd tracks together - no problem . stop 1st track and load up 3rd track - sound to speakers cuts out and will only come back on if i move the headphone control on the dj console is moved backwards and forwards... after that no problems.
6 try to use the loop function and find it has reset itself from 8 bars default down to 4 bars - and have to reset it for each track !
7 get v annoyed !
its the loop thing that is the most annoying , i can live with the rest...
any help appreciated
justin
1 turn computer on
7 get v annoyed !
justin
geposted Wed 24 May 06 @ 6:49 pm
Hi,
2- You can't do that with the demo version
4- Cracked version problem...
Buy the full version to fix all your problem, there is no other way
geposted Wed 24 May 06 @ 7:12 pm
it isnt cracked or a demo its the full version with the mk2 console ! ( im not a freeloader !!!)
geposted Wed 24 May 06 @ 7:15 pm
ps the looping problem just happened an hour ago while i was trying to put a mix together...
geposted Wed 24 May 06 @ 7:18 pm
Hi just enter your serial number in your profile
geposted Thu 25 May 06 @ 3:52 am
You can add your serial here: https://virtualdj.com/fusers/modifuser.html
geposted Thu 25 May 06 @ 2:49 pm
just added serial number and downloaded update - will this fix the problems ?
cheers
justin
cheers
justin
geposted Thu 25 May 06 @ 6:12 pm
