When I play a track the audio tends to jump a few beats ahead randomly once per side per track. Its wierd... How do i get rid of it? It didnt used to happen...|
I am using virtual dj 3.2
:// DJ Xsjado
:// DJ Xsjado
geposted Wed 24 May 06 @ 10:30 pm
That happens to me when I try to use TCV. Still waiting for a response in the hardware section. But I'd suggest you update to 3.4, and if this is happening without TCV and just as regular mp3s you might need to free up system resources. See above "skipping: solutions". Unfortunatly it didn't help me much with my TCV problems;^[
geposted Wed 24 May 06 @ 11:12 pm
update !
geposted Wed 24 May 06 @ 11:50 pm
Ive updated and my hardware is off the charts
amd 64 3500+
1gb ddr low latency ram
256mb xfx 7800gt pci-e
windows xp pro
audigy 2 soundcard
200gb sata hdd with the music on it
80gb ultra ata (ide) hdd with windoze on it
the skipping never occurred before on this machine untill after i reinstalled windows recently
amd 64 3500+
windows xp pro
audigy 2 soundcard
geposted Thu 25 May 06 @ 2:52 am
"the skipping never occurred before on this machine until after i reinstalled windows recently"
Did you reinstall all drivers, all windows updates, Direct X updates? Are you sure that the Windows install, was flawless? If it worked before the reinstall, then something is missing. Also make sure VDJ configurations are as they should be.
geposted Thu 25 May 06 @ 7:46 am
everything is perfect divers are all from their manufactureers and updated and everything
could it be because i have 2 soundcards acitive (not same IRQ)
geposted Sat 27 May 06 @ 3:56 am
Do you use advanced sound config?
geposted Sat 27 May 06 @ 8:40 am
Are you running the Audigy with Asio drivers or with the Windows drivers?
Ewout
Ewout
geposted Sun 28 May 06 @ 11:59 pm
I just solved mine, if in ASIO you may want to try & increase buffer size;^]
geposted Mon 29 May 06 @ 12:08 am
