Hey im new to this turntables to connect to the pc. How do u connect it? I bought new computer with the three jacks in the back.(Red Blue and Green Jackes). I heard that u can connect it and if u have the time coded vynil which i bought(The Record) but i dont no how to it controls it. If anyone can teach me ill be happy. O yea can u show pics where i connect where? Thanxs. ;)
geposted Thu 25 May 06 @ 12:58 am
you have to connect your TT to line in (usualy green) at your sound card in computer. red jack in is for microphone. blue is line out.
you have RCA connectors at your turntable's cable, so you will need RCA-to-minijack adapter.
See my blogs for explanation of audio connectors:
https://virtualdj.com/blog/xeon/blog2698.html
https://virtualdj.com/blog/xeon/blog2723.html
Then you will need to configurate your TC signal.
geposted Thu 25 May 06 @ 10:53 am
of course u need vdj pro for this to work cracked versions and the trial only support one vynal. , and the latest updates would be better , if u have bought it add ur serial to ur profile to get updates.
geposted Thu 25 May 06 @ 11:16 am
You can modify your profile here: https://virtualdj.com/fusers/modifuser.html
geposted Thu 25 May 06 @ 2:32 pm
