Forum: VirtualDJ Skins
Topic: How to change skins-Step by Step pls?
Tried to follow what it says on the previous thread but somehow can't get it. Could anyone please tell me how to change the skins step by step pls?
geposted Sun 28 May 06 @ 6:19 pm
CONFIG > SKINS > Select desired SKIN.
Is this?
Is this?
Some skins say SET, rather than CONFIG - one or two have symbols instead of words - just hold the pointer over that and see what the Tool Tip says.
i have the same problem as well, my version is 4.2 i go to change skins, only i found is the default skins...
Your version is 4.2 ...
Are you from the future or something? latest version is 3.4!
