I want to be able to locate songs that i am looking for. But when i got to search i can only find the song on the Genre that i am in. Is there anyway the i can just put the name of the song into the search field and virtual can locate the song in all different genres or name matches??
geposted Sun 28 May 06 @ 10:32 pm
DJ Boli,
please search the forums, while this question is answered a couple of times before (the same for your question about the licence).
Before you can search you will have to scan your hard drive for files:
- Open VDJ
- In the File browser on the left side, select Local database
- Right click and select "Scan HD"
- Select the drive(s) where your songs are located
- Click OK
- Wait until the search is finished
Now if you like to search you could
- Select the folder and enter a search phrase, to search within that folder
- Select local database and enter a search phrase, to search all your files
Ewout
- Open VDJ
- Click OK
Ewout
geposted Sun 28 May 06 @ 11:47 pm
