Hi... i use a EDIROL UA-20 usb external card and I cant hear the mic with VDJ ... but with other programs is working perfectly ... i dunno what to do... the mic volume is alqays to the top
geposted Mon 29 May 06 @ 1:09 am
VDJ has nothing to do with MIC in case you are using default skin. If you are using skin with MIC control, check them. Mic should work in VDJ if it works in other software. It should work even without any software opened.
geposted Mon 29 May 06 @ 8:42 am
geposted Mon 29 May 06 @ 1:49 pm
