Forum: VirtualDJ Skins
Topic: Low Res Skin
Hi folks.
I'm currenttly running my pc through a 21"tv, basically asn it lies next to my decks and my monitor is currently in storage.
Problem i'm having is viewing the media library. i am currently running at 800 x 600 and the text is virtually invisible. Is there any way in which I can expand this text?
I really have no idea in the slightest about skining.
Any help would be really appreciated.
geposted Tue 30 May 06 @ 11:25 pm
You can use my little software VDJ Skin Resizer (you can find it in the same forum). Just replace defaults Search Criterias field by "size=" without quotes, it will then only resize the text.
Tell meif you encounter a problem.
Cya!
