Ok so i used it again this weekend....6 hour gig. A few times the effects started engaging themselves. I had a break effect loaded on each deck and for some reason the songs decided to break on there own....
The BEATLOCK started driving me crazy a few times.....after you fade over you have to remember to uncheck the beatlock on the side playing because if u load a new song and hit play to cue the song playing will jump up or down in speed. At the beginning of the night i was fine but as a few drinks got into me i forgot and i had a couple songs jump from like 143 BPM to 135....a drastic difference....
and lastly......a couple times when i would have the beatlock on i would hit play and the Tempo's would be the same but the BPM sprokets were not lining up....they were exactly a half beat off...
geposted Mon 14 Jun 04 @ 1:55 pm
did you have any shortcuts assigned to your effects? you may have been hitting the shortcut key by accident after your few drinks...
geposted Mon 14 Jun 04 @ 2:08 pm
NOPE....NO EFFECT SHORTCUTS......i thought the same thing
geposted Mon 14 Jun 04 @ 5:23 pm
See if that happens when you are drinking water..........LOL.
geposted Mon 14 Jun 04 @ 7:15 pm
