Forum: VirtualDJ Skins
Topic: DAC-3 1024 *768 - Is it available??
Hats of to Muzza for creating the DAC-3 skin.
It's not currently available in 1024*768. I tried resizing it last night using the utility on the VDJ site, but couldn't get it to work.
Has anybody converted it? Or are there any plans to do a DAC-3 skin in this size?
geposted Thu 01 Jun 06 @ 11:35 am
Did you tried with VDJ Skin Resizer ?
I just tried, and if you did then you could encounter two difficulties: unproportional resize, and logo size. For the first, for the moment it is not automatically supported but you can make it work just following included instructions, and for logo size sorry I can't do much about that, you must correct the problem manually.
In the wait that the official author make a true low res, here is the one I worked, but due to logo size problem it has a yellow line at the bottom, but the skin is fully functional: http://www.megaupload.com/?d=JSTD5QA6
Note: The buttons works but I don't know for DAC3 functions because I don't have any external hardware, but I don't see why there would be a problem...
Hope it'll help you.
Cya!
Hi
Thanks so much for taking the trouble to help with this.
I did try skin resizer, but could't figure out how to make it work because it gave an error message about the xml and skin sizes being different.
Once again, thanks a lot and I'll report back on how it goes with the DAC-3.
i will fix the bugs and repost this dac 3 skin 1024 \ 768 by Muzza
Cool ;))
What about your version of dac 3 DJ FORMAT, are you still working on it?
YES Here's is a sample of the graphics Comeing Soon
that 's going to be the best b]
LCD DISPLAYS
YOU CAN SWICH THE COLOUR OF THE DISPLAYS
congratulations DJ Format i have ready from pcdjfx is very nice tank's
@ asymptote,
I have had a very busy schedule lately and finding enough time during the day for leisure activities has been somewhat difficult to say the least.
If you are interested in modifying the skin i could send you the psd file. Making a 1024 x 768 would be benificial to many users.
Cheers!
Thanx Muzza
Not sure if I know what to do, but would be happy to try.
Asymptote.
