Forum: VirtualDJ Skins
Topic: Resized Skins
If there is anyone who has successfully re-sized skins, can you please post the new versions for everyone else?
Credit would still go to the original creator of the skin.
Thank you.
geposted Thu 01 Jun 06 @ 12:36 pm
I have successfully resized some skins and have posted them.
Do you have a particular skin that you would like to see in a particular resolution?
Yes, I would like wide screen versions of the MIXSTATION skins.
How can we tell which skins have been modified?
Thanks for doing that.
I don't want to sound selfish but I released a little software that may do the work, but I think you will need to perform a little trick to do an unproportional resize, but after doing it once you will be able to do it for every skin ;)
I think that five minutes are not a great deal to be able to use any skin you want =)
OK, I understand, Sorry.
I was not able to get it to work.
I will continue to use the original skins until I solve it.
You don't have to be sorry, you can do the way you want and use the softwares you want ;)
Please tell me the full name of the skin (if there are many different versions) and the resolution you would like and I'll see what I can do =)
Cya!
For sure being a DJ is not the same as being a computer engineer ;)
Here is your skin resized: http://www.megaupload.com/?d=6HKVO9MN
As before, problem with font's size, so I corrected it. But I didn't corrected knob graphic bug, but the functionality should be here =)
Enjoy =)
Cya!
thank you
