Hello Guys !
First of all i´m thinking to buy Virtual DJ 3.4 for a "home" use.
I´m only want to play for hooby. I don´t want any professionl advice... i want only to you guys to help me setup my lap top to play "as DJ" with my friends.
I´m from Brazil...and i don´t want to spend too much money and I DON´T HAVE too many "way out" to buy a right USB Sound Card... My only choices here is SOUND BLASTER ones..
I don´t have access to any other brand of USB Sound Card.
I bought recently one HP DV8000z lap top
There´s a "suckon" sound card onboard called CONEXANT AMC Audio.
There´s ONLY one LINE OUT (Called "Headphone out w/ SPDIF Digital Audio")
So i guess my sound board is NOT a 4.1 or more channels outs....
Any details you can found here:
http://www.shopping.hp.com/webapp/shopping/computer_series.do?storeName=computer_store&category=notebooks/hp_pavilion/dv8000_series&series_name=dv8000z_series&catLevel=3&tab_switch=true&tab=specs
So i think i cannot use the headphone (for me only listen) / master (for the people listen)
Is that ok ???
There´s the USB SOUND BLASTER who i have access.
- Sound Blaster Live! 24 bit External (USB)
http://www.creative.com/products/product.asp?category=1&subcategory=206&product=10702
- Sound Blaster Audigy 2 NX (USB)
http://www.creative.com/products/product.asp?category=1&subcategory=205&product=9103
(I think this is too much expensive for me too)
- Sound Blaster MP3+
http://br.creative.com/products/product.asp?category=2&subcategory=18&product=154&nav=features
( I think this is a 2 channel out only ! i think i only work with i use my ON BOARD sound for headphone and this sound card to master... ok ? or not ?)
My questions:
- How workd this called "STEREO SPLITTER" ?
I have to bought some "hardware" do put headphone/master together ?
I have a "simple splitter" that i use on my IPOD to work 2 headphones at the same time.
Is this work for me ?
- Can i use one of that above USB cards from Sound Blaster AND my on board sound together in VDJ ?
- I dont want to do professional sound.. but theses USB cards will "make" a sound at least
"regular" or "good"
Help me please and sorry for my bad english..
Thanls to all
Is that ok ???
My questions:
"regular" or "good"
Thanls to all
geposted Thu 01 Jun 06 @ 8:12 pm
hi the only way you'll be able to have the Cue ability of the headphones is by buying the program..the demo version has this feature disabled
geposted Thu 01 Jun 06 @ 8:14 pm
Yeah... O know that..
And i don´t question on that topic...
But if you know...please...answer my other questions... ;)
geposted Thu 01 Jun 06 @ 8:24 pm
Other thing...
I cant "figure out" how can this work..
For example...
To do this "STEREO SPLITTER" i have to "have" a "special cable" or something like that !???
I have one cable that connects to any line out of a sound card ( sorry..i dont know how to call that plug) and in the end have 2 other connectors (i think it´s called RCA) that i usually plugs in my stereo system (LEFT / RIGHT)
So i suppose that one channel (for example the LEFT) goes do a HEADPHONE and another channel (for example the RIGHT) goes to MASTER (stereo system)
So.. i have to found 2 adapters.
- One to make 1 RCA to 2 RCA (for the Stereo System)
- Other to make 1 RCA to HEADPHONE ( i have a HEADPHONE whichs use the SAME PLUG of the sound board or a IPOD for example..i don´t know the name)
Is that TRUE ?
For example...
Is that TRUE ?
geposted Thu 01 Jun 06 @ 9:27 pm
hello, for tutorial of plugs look at my blog: https://virtualdj.com/blog/xeon/blog2698.html
here is nice description how to make stereo splitter: https://virtualdj.com/blog/Coyote/blog1794.html
here you can see how to make it using adapters: https://virtualdj.com/blog/cioce/blog2866.html
hope that helps ;)
hope that helps ;)
geposted Thu 01 Jun 06 @ 11:06 pm
Thanx for the PLUGs Tutorial Xeon...
But the others (most important i think) don´t wok
i tried
and
(with HTM on the end and NO HTML)
but i didn´t found anything that helps me there !
Ohhh my..
anyone can help me on that please ?
i tried
and
Ohhh my..
geposted Thu 01 Jun 06 @ 11:21 pm
oh yes, it is for home edition users only... you won't be able to use this option in trial version! you have to buy it! i can add those pics to my blog just to see what is stereo splitter if you want.
geposted Thu 01 Jun 06 @ 11:25 pm
Oh Yeah !
If you do that i will thank you !
I know that option is only for the FULL version.
My question is about the "hardware" (cables , plugs etc) and not for the "software" (for example options>stereo splitt etc....bla bla bla)
Thank you very much Xeon
geposted Thu 01 Jun 06 @ 11:55 pm
Hello fellas
Anyone can give me a advice about this product ?
I found a USB Zalman ZM-RSSC to buy here.....
Here are the specs..
Input 1 USB Connection Port(USB 1.1/2.0 Compatible)
Output 3.5mm Stereo Jack x3(Front, Rear, Center/Subwoofer)
0.6W per channel, 1 Digital Port (Both Optical & Coaxial, capable of outputting 5.1 channels)
Chipset Sonix 5.1 Sound
Sampling Rate 24bit 96KHz D/A & A/D Converte
Size 80 (W) x15 (H) x 108 (D) mm
Power Consumption Minimum 3.3V, 150mA (Standard 5V, 500mA)
and a photo
http://www.zalman.co.kr/images/product_img/audio/ZM-RSSC_ins_2.gif
Works well ?
and a photo
Works well ?
geposted Tue 06 Jun 06 @ 5:22 pm
