Forum: Old versions
Topic: TCCD - what to buy if i get VDJ???
Please help me and pass me advice on where to buy TCCD that is compatible with denon dn-s5000's and would be with VDJ?
Which is the longest playing as well...
Thanks
Tom :)
geposted Thu 01 Jun 06 @ 9:07 pm
You could download the mp3 for a tccd for free here!
https://virtualdj.com/products/timecode/VDJTimeCode.mp3
You have to burn this mp3 as an audio cd at the lowest speed of your burner. Then you will need a sound card that supports Asio.
Note that only one deck is available in the demo version.
Ewout
hi thanks fot that...
thats only 12 mins long, are there any that i can buy?
cheers again
I use Pioneer CDJ-800's with a maya 44 usb card and it works great so far for me
hallattj
Check apopsis blog he's found a different way to create tccds with 3 tracks, and they work perfectly using pro version, hope to see you soon as a registered user, regards.
tccd's could not be purchased, only the vinyls are for sale, but they're also 12 minutes long.
How many tracks do you have longer than 12 minutes? Also note that if the time code track is finished (after 12 minutes) VDJ will continue playing at the same speed as has been before the timecode signal stopped. So if yoy set the turntable or cd player at +4%, VDJ will continue playing the mp3 at +4% after timecode is finished.
Ewout
