hi all i am trying to get hercules working with traktor dj i have been reading the pdf that i downloaded for hercules web site and it shows a box with asio settigs for hercules djmp3 it says you must use such and such settings for it to work my problem is i can not find this box please help cheers
geposted Fri 02 Jun 06 @ 6:00 pm
Hey djhandz, this is the forum of VIRTUAL DJ and not hercules or traktor forum!!!
You don't like Virtual DJ? Why?
VIRTUAL DJ IS THE BEST MIXING SOFTWARE!!!
geposted Fri 02 Jun 06 @ 6:26 pm
Look for hercules under "all programs", if you still can't find it there, open up your c drive then open up program files from there & then open up the hercules folder. It should appear in both of those places;^]
geposted Fri 02 Jun 06 @ 7:04 pm
You will find the Hercules setting icon, inside Windows Control Pannel, if it does not show in the system tray automatically when Hercules is connected
hope that helps :)
hope that helps :)
geposted Fri 02 Jun 06 @ 7:30 pm
thanx all i sorted it cheers
geposted Fri 02 Jun 06 @ 8:54 pm
