Forum: Old versions
Topic: BeatLock Light is out!
If you pressed the "beatlock" button in V1.9 it would appear a differnt color indicating its use, but in V2 the "beatlock" light never goes on so you can't tell whether it is active or not.
Please let me know if a remedy is on the way.
Erik
geposted Mon 14 Jun 04 @ 10:18 pm
Which skin are U using? Maybe it isn't compatable with VDJ2, as the beatlock way has changed.
FRUiT94
