I have installed Virtual DJ at least 10 times (and removed it in between of course) and it won't launch. the title page appears and then nothing happens. Any Suggestions are welcome.
geposted Sun 04 Jun 06 @ 5:07 pm
if your screen resolution is set to 800x600 change it to a minimum of 1024x768
geposted Sun 04 Jun 06 @ 5:23 pm
if it shows on the taskbar then djzero is correct change your screen resolution if not then try uninstalling and removing and trace of it from your registry before reinstalling
geposted Sun 04 Jun 06 @ 7:30 pm
