I've been using VDJ for a while now to mix music video on my laptop and always wanted the files to load quicker. It takes anywhere from 30 seconds to a full minute to load a video file (depending on it's size, of course)--which can REALLY be valuable time lost in the dj world. Though I haven't really run into any problems with this, it can be annoying when I want to get creative with a particular mix.
But anyway...I've got a Dell Inspiron 6000 with 1.60 Ghz Pentium M processor, 1 Gb RAM, and an integrated Intel 915GM video card. All files are coming from a Maxtor One-Touch 300-gig external hard drive. (Should I be using two separate drives or is one sufficient?) Is my setup running the way it should or have I been missing out?
Any input would be appreciated.
geposted Mon 05 Jun 06 @ 5:22 am
Could be the Pentium 1.6, or the graphics card. I too have a Pentium 1.6 with the same graphics card and have problems. You need to have a better graphics card to attempt to play video. I bet there are some users that have made it work and I too would like to know how they did it. Cheers Brian
geposted Mon 05 Jun 06 @ 6:54 am
Actually my guess would be the USB transfer and the fact that you are only running @ 1.6 ghz in addition to your CPU doing the majority of the video work. Remember VDJ is doing a LOT of things, but gives priority to the music or video playing. VDJ will use as much CPU possible to load the video quickly, but if you don't have the horsepower it will be slow, no matter what. Usually laptops with Intel onboard graphics will rely on the CPU to do much of the work for it. Where an NVIDIA or ATI chipset will offload the graphics work to the card itself to free the main CPU for other things. (Like loading your video.)
geposted Tue 06 Jun 06 @ 5:04 pm
are u tranfering at 2.0 usb speeds? might have to do with the external tranfer speeds
geposted Tue 06 Jun 06 @ 9:27 pm
The 6000's have four USB 2.0 ports.
geposted Tue 06 Jun 06 @ 9:36 pm
more usb's don't make it faster try a video from ur internal hd and see how that does
geposted Wed 07 Jun 06 @ 1:47 am
Agreed, it is probably the combination of a slow cpu and using a graphics card not designed for this sort of task.
geposted Wed 07 Jun 06 @ 8:51 am
