hi my english is litel bad and i hope you will understand me.
i hav a djc mk2 and time coded viliny and evrithing is runing great but vhen i whant a litel of scratching the siginal and the code is bad and the sound is like star wars and is not god.(vdj get down in his movie is scratching and the sound is cool but in my case in not it is like a laser)
pleas tell me what to do or what setings should i use bufer........
thank you!!!
thank you!!!
geposted Tue 06 Jun 06 @ 12:28 am
Well first, you must have a full version in order to make the tcvs work good but the demo will let you play with one of them for 5 min. Which is not bad. Ok now for your problem. I think the problem you have is the sampling rate. Try to set your console at 44.1 for sampling rate. You can set that in the console control panel (little green alien head).
Hope it works and that you get the full version soon.
geposted Tue 06 Jun 06 @ 12:05 pm
also make sure you have plenty of memory (ie: 1GB or Ram)
geposted Tue 06 Jun 06 @ 12:25 pm
if it sounds star war-ish then it might be the buffer settings, check and see what its set at and either up the buffer amount or lower.
geposted Tue 06 Jun 06 @ 2:05 pm
thenk you all i will try to sort ut this .
geposted Tue 06 Jun 06 @ 11:11 pm
